Always block equivalent construct
I am trying to model a Design in SV for verification purpose.
I am looking for construct which works similar to always block in verilg but can eb used inside class
eg: always(posedge clk, reset)
I am looking for some construct which works the same but can be used inside a class.
I am assuming, we can not use always block in a class
Hi Bhaskar,
Always block cant be used inside a class.
I can suggest you to use forever block inside the class which meets your requirments of always block inside a class
For More information visit
Assuming you are in a task like run (OVM) or run_phase(UVM), you can always do
task run;
   forever @(posedge v_itf.clk)
join_none
Dave Rich
go.mentor.com/drich
Hello Dave
I am actually looking for an equivalent for
always @(posedge clk, negedge resetn) begin
code1;
where I can have the sensitivity list for the same block of code.
The same can be written using fork join as shown below:
forever @(posedge clk)
code1;
forever @(negedge resetn)
code1;
join_none
Here I am duplicating code1. which I want to avoid.
Can you give me an example where I can have sensitiity list used in classes.
In reply to pbhaskar:
Syntactically, you can put anything after forever that you can put after always. So you can have
  forever @(posedge clk, negedge reset)
         code1;
join_none
