How can i control the duty cycles between request and grant in an ahb bus arbiter using system verilog assertions,in order not
to transcend a limit such as ##10 between req and grant and then if this limit is outreached an error message should be displayed.
And secondly,how can i control by creating a system verilog assertion if two grant signals are simultaneously active?
/*How can i control the duty cycles between request and grant in an ahb bus arbiter using system verilog assertions,
in order not to transcend a limit such as ##10 between req and grant and then
if this limit is outreached an error message should be displayed. */
// Two choices: 1) You could define that duty cycles limit as a parameter
// 2) Define it as a variable and use that in a property with local variable
// for example
module m;
parameter int d=10;
int dc=10;
bit clk, req, ack;
p_with_parameter: assert property(@(posedge clk) req |-> ##[1:d] ack);
property p_with_var;
int v_dc;
(req, v_dc=dc) |-> ##[1:$] (ack, v_dc=v_dc-1'b1)[*1:$] ##0 v_dc==0;
endproperty : p_with_var
a_p_with_var: assert property ( @(posedge clk) p_with_var);
endmodule : m
/*And secondly,how can i control by creating a system verilog assertion if two grant signals are simultaneously active?*/
/* See
https://verificationacademy.com/forums/systemverilog/sva-question-0
Ben Cohen Training for VMM, SVA (831) 345-1759
- A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
- SystemVerilog Assertions Handbook, 2005 ISBN 0-9705394-7-9
- Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0
- Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 0-9705394-2-8
- Component Design by Example ", 2001 ISBN 0-9705394-0-1
- VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1
- VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115
