Thanks Dave, without above suggestions, especially using dynamic array instead of queues has improved performance a lot.
Also since end address we were only using to calculate for 4kb boundary, so removed it altogether.
However considering for me num value is in range of close to more than 'd3000+ so still seeing some hangs on max values.
One trivial query:
You could calculate bsz, bl, and the array sizes in pre_randomize to simplify the constraint equations.
By this you meant that in pre_randomize() following needs to be done :
class tr_gen;
rand bit[1:0] bsz;
rand bit[31:0] s_addr[];
rand bit[2:0] bl;
bit[31:0] addr_4KB_msk = ~((32'('h1) << 12)-1);
rand bit[5:0] num;
constraint c_tr_n {
s_addr.size() == (num+1); // number of transactions
constraint c_s_addrs {
foreach(s_addr[it]) if(it>0) {
s_addr[it] == s_addr[it-1]+((bl+1)*(2**bsz)); // consecutive start addr = addr + total num bytes in transasction
constraint c_4kb_boundary {
foreach(s_addr[it]) {
(s_addr[it] & addr_4KB_msk) == (s_addr[it]+((bl+1)*(2**bsz)-1)) & addr_4KB_msk); // for every transaction ensure 4kb boundary
// constraint only s_addr[0]
constraint c_s_addr_byte_align {
bsz == 1 -> s_addr[0][0:0] == 0; // 2 byte
bsz == 2 -> s_addr[0][1:0] == 0; // 4 byte
bsz == 3 -> s_addr[0][2:0] == 0; // 8 byte
function void pre_randomize();
randomize(bsz,bl); // randomize
bsz.rand_mode(0); // no further randomize required for bsz
bl.rand_mode(0); // no further randomize required for bl
// num is passed as inline constraint will reflect here ?
s_addr = new [num+1];
c_tr_n.constraint_mode(0); // no further constraint required
module try;
tr_gen tr;
tr = new();
void'(tr.randomize() with {
num == 5;
// use tr
