In reply to bhupeshpaliwal:
I was able to get a result for num == 63, which is the largest possible value, for all simulators on EDAPlayground. I noticed you had some typos (= instead of ==), so maybe you did not copy the example correctly and missed something. Or maybe you have hit a tool specific issue. Some comments for optimizations:
- Use dynamic arrays instead of queues [$] for quicker access unless you plan on pushing or popping values.
- You only need to check s_addr[0] for byte alignment.
- You could calculate bsz, bl, and the array sizes in pre_randomize to simplify the constraint equations.
- You could calculate e_addr in post_randomize to simplify the constraint equations.
