Let’s say I would like to generate a sinusoidal real valued signal.
There are two ways to generate it:
[1]: I can generate it using purely system verilog codes
[2]: I can generate it using C language
Now, if C language has been used, then, DPI-C is required to interact with System Verilog and ultimately, which will produce a sinusoidal wave in real valued.
The desired signal should be real valued signal.
Now, which one between [1] and [2] said above, will be the optimum way to generate a sinusoidal signal?
Any lucid elucidation will be highly appreciated.
Thank you.
