When I add the `uvm_info to the existing component I see change in the behaviour of the code.
Below is the code for AXI master driver component ; when I comment the uvm_info all the transaction items from the sequencer are driven and is seen on the waveform while if I enable the
uvm_info I see that the driver shows the first beat in the second burst transfer to be driven but is not seen in the waveform.
Can the behaviour of code change when we add uvm_info statement?I see it happening just by commenting and uncommenting
uvm_info statement . If so, how does it affect? How to fix it?
Below is the code:
task ma_driver::send_to_dut(ma_xtn xtn);
apply_reset();
//`uvm_info("FROM MASTER DRIVER","HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHELLLO",UVM_LOW);
@(vif.madrv_cb);
dly =$urandom_range(m_cfg.awaddr_to_awdata_lead_delay_min,m_cfg.awaddr_to_awdata_lead_delay_max);
if(m_cfg.awaddr_to_awdata_config == LEAD)
repeat(dly) @(vif.madrv_cb);
wr_data(xtn);
join
Below is the task which behaves differently when `uvm_info enabled or disabled
task ma_driver::wr_data(ma_xtn hdl);
foreach (hdl.wr_tr[i])
//@(vif.madrv_cb);
foreach(hdl.wr_tr[i].Wdata[j])
`uvm_do_callbacks(ma_driver,master_driver_callback,pre_wr_data())
if(m_cfg.wr_data_stream == OFF)
vif.madrv_cb.Wvalid <= 'b0;
vif.madrv_cb.Wlast <= '0;
vif.madrv_cb.Wdata <= '0;
dly =$urandom_range(m_cfg.wr_addr_stream_min,m_cfg.wr_addr_stream_max);
vif.madrv_cb.Wvalid <= 'b1;
vif.madrv_cb.Wdata <= hdl.wr_tr[i].Wdata[j];
$display("$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$i=%d,j=%d,wdata=%d",i,j,hdl.wr_tr[i].Wdata[j],$time);
vif.madrv_cb.Wstrb <= hdl.wr_tr[i].Wstrb[j];
if(j == hdl.wr_tr[i].Awlen)
vif.madrv_cb.Wlast <= 'b1;
`uvm_do_callbacks(ma_driver,master_driver_callback,post_wr_data())
@(vif.madrv_cb);
if(vif.madrv_cb.Wready);
wait(vif.madrv_cb.Wready);
@(vif.madrv_cb);
vif.madrv_cb.Wlast <= 'b0;
vif.madrv_cb.Wdata <= 'z;
@(vif.madrv_cb);
When `uvm_info is uncommented I see that the i=1;j=0 value is driven by driver but not seen in the wavefrom
when it is commented it drives and the same can be seen on waveform. Not sure .why…
Shilpa
