Achieving Unique Array via inside operator
Hi all ,
I was trying if I could achieve a unique array without array.sum() / unique constraint .
So I tried the following ::
module  UNIQ_via_inside ;
  class   Main ;
    rand  bit [2:0] b [] ;
    constraint  SIZE {  b.size()  ==  5 ;  }
    constraint  UNIQ  {
                          foreach( b[ i ] )
                           if(  i == 0 )
                             !( b[i]  inside { b[ ( i+1) : ( b.size() - 1 ) ]  }  ) ;
                             else if ( i == ( b.size() - 1 ) )
                              !( b[i]  inside { b[ 0: ( b.size() - 2 )] }  ) ;
                             !( b[i]  inside { b[0 : ( i - 1 ) ] , b[ ( i + 1 ) : ( b.size() - 1 ) ]  }  ) ;
  Main  m1  ;
  initial  begin
    m1 = new() ;
    repeat( 5 )
       if( m1.randomize() )
         $display("Success  with  %0p " , m1.b);
         $display(" FAILS ");
This however doesn’t work due to Illegal Slice Compilation Error
Any suggestions ?
In reply to Have_A_Doubt:
constraint  UNIQ  {
    foreach( b[ i ] )
    foreach( b[ j ] ) {
if (i != j) b[i] != b[j];
In reply to Jianfeng_0:
My apologies , I forgot to mention that I was trying to achieve unique without the above dual foreach logic too .
https://verificationacademy.com/forums/systemverilog/unique-array-elements-without-rand-or-randc
Dave ,
Need suggestions with the following logic ::
rand  bit [2:0] bhelper[][] ;
      bit [2:0]  N  = 5 ;  //  Can  be  changed  at  Run - Time .
    constraint  SIZE   {  b.size()  ==  N  ;  }
    constraint  SIZE1  {  bhelper.size() ==  b.size() ; }
    constraint  SIZE2  {    foreach( bhelper[ i ] )
                             bhelper[i].size() == ( b.size() - 1 ) ;
    constraint  VAL     {     foreach( b[ i ] )
                                ! ( b[ i ]  inside { bhelper[ i ] } )  ;
     //  Need  Logic  here  to  constraint  elements  of  bhelper  !!
The constraint logic should be Generic . For N == 5 it would be as follows ::
 //  b[0]  Should  Not  Occur  within  bhelper[0]  ::
 bhelper[0][0]  == b[1] ;  bhelper[0][1]  == b[2] ;
 bhelper[0][2]  == b[3] ;  bhelper[0][3]  == b[4] ;
 //  b[1]  Should  Not  Occur  within  bhelper[1]  ::
 bhelper[1][0]  == b[0] ;  bhelper[1][1]  == b[2] ;
 bhelper[1][2]  == b[3] ;  bhelper[1][3]  == b[4] ;
//  b[2]  Should  Not  Occur  within  bhelper[2]  ::
 bhelper[2][0]  == b[0] ;  bhelper[2][1]  == b[1] ;
 bhelper[2][2]  == b[3] ;  bhelper[2][3]  == b[4] ;
//  b[3]  Should  Not  Occur  within  bhelper[3]  ::
 bhelper[3][0]  == b[0] ;  bhelper[3][1]  == b[1] ;
 bhelper[3][2]  == b[2] ;  bhelper[3][3]  == b[4] ;
//  b[4]  Should  Not  Occur  within  bhelper[4]  ::
 bhelper[4][0]  == b[0] ;  bhelper[4][1]  == b[1] ;
 bhelper[4][2]  == b[2] ;  bhelper[4][3]  == b[3] ;
I cannot see how you could build bhelper without two nested foreach loops.
Given that this a very contrived coding question for you to solve with an impractical solution, I will not do your work for you.
