I have a struct defined inside a class as follows:
class test;
typedef struct packed{
logic c;
logic d;
}pkd_flds_s;
I’m trying to access members of this struct inside another class as follows:
test t;
t = new();
logic l = t.pkd_flds_s.c; //Method-1
logic l = t.c; //Method-2
Using both these methods I get the error: Cold not find member “c” in class ‘test’. How can I access the elements c and d in another class?
In reply to vikrant_sharma:
You have only declared the type, not a variable.
I also tried to do declare a variable of type pkd_flds_s as follows but it didn’t work. Is this what you were suggesting?
test t;
t = new();
t.pkd_flds_s inst; // Create a variable of type pkd_flds_s
logic l = inst.c;
It would help to show a complete example. The following worked for me
class test;
logic c;
logic d;
} pkd_flds_s;
test t;
test::pkd_flds_s inst;
logic l;
t = new();
inst.c = 1;
l = inst.c;
$display(l);
