consider a DUT where it takes in an image, process, and send out an image. the interface for that DUT has frame/frame_rdy/pixel_xmt_rdy/pixel_rcv_rdy/pixel_data. The function model for DUT is written in C so some DPI is involved to generate expected output. The C model only takes full picture as input/generates full picture as output.
I’m thinking about making object representing a pixel as the base sequence_item, and use a sequence to represent a picture. Therefore, the interface agent won’t need to know much other than driving one pixel. In this scenario, what’s considered best practice for me to pass a picture to DPI for processing? My understanding is that if I use a subscriber and collect the transaction on the input interface, I’ll get pixels instead of pictures, and I would like to get a picture and get expected results before actual RTL transaction happen.
Another way is to write 2 different drivers(one takes pixel, the other takes picture) and use factory to overload. The monitor would still only capture pixel. In this case, I can send the picture object to another component which deals with DPI, and generate a sequence of pixel object for output checking. In this scenario, is it considered good practice for driver/monitor in the same agent take/generate different types of sequence_item?
Any suggestion is appreciated
