why initial block is not allowed inside the class?
In reply to Lakshman4178:
If you check the 1800-2017 SV LRM section 9.2 Structured procedures, you find the following
“The initial and always procedures are enabled at the beginning of a simulation. The initial procedure shall
execute only once, and its activity shall cease when the statement has finished. In contrast, an always procedure shall execute repeatedly, and its activity shall cease only when the simulation is terminated.”
A class object can be created dynamically at any time, “any” number of times, therefore allowing the initial block in a class will be violating the above specified description.
HTH,
-R
