I am trying to write some constraints for a 2-D dynamic array. The requirement being addition of the values for each row and column needs to be 30.
class hello_world;
rand bit [7:0] a [5][4];
constraint a_row {
foreach (a[i]) a[i].sum() with (int'(item)) == 30;
constraint a_col {
foreach (a[i]) a.sum() with (int'(a[item.index][i])) == 30;
module test;
hello_world m1;
int temp;
m1=new();
assert(m1.randomize());
This gives me a constraint solving error :
“xmsim: *W,RNDREJ: This constraint was not processed due to: array index out of bounds
foreach (a[i]) a.sum() with (int’(a[item.index][i])) == 30; (./testbench.sv,9)”
Not quiet able to understand how is this constraint to access at the array index out of bounds.
In reply to fenil_shah:
You need to iterate over the second dimension. I would also use j as the iterator variable name so you don’t confuse it with i [,j].
constraint a_col {
foreach (a[,j]) a.sum() with (int'(a[item.index][j])) == 30;
I tried that too, but now it complaints that
"xmsim: *W,RNDOCS: These constraints contribute to the set of conflicting constraints:
foreach (a[,j]) a.sum() with (int'(a[item.index][j])) == 30; (./testbench.sv,9)
foreach (a[i]) a[i].sum() with (int'(item)) == 30; (./testbench.sv,6)"
That’s a different problem. Your puzzle only has a solution if NRow*SumRow == NCol*SumCol. Try
class hello_world;
constraint a_row {
foreach (a[i]) a[i].sum() with (int'(item)) == 40;
constraint a_col{
foreach (a[,j]) a.sum() with (int'(a[item.index][j])) == 50;
Or even more compactly
constraint a_r_c {
foreach (a[i,j]) {
I did not quiet understand NRowSumRow == NColSumCol and why did changing the sum of the columns value to 50 work?
Try on paper with a smaller example with a[2][3] and find a solution where the sums of the rows and columns are both 3.
According to what I understand it works as below. Please do correct me where am I going wrong.
rand bit [7:0] a [2][3];
constraint a_r_c {
foreach (a[i,j]) {
a[i].sum() with (int'(item)) == 3; // a[0][0] + a[0][1] + a[0][2] == 3
// a[1][0] + a[1][1] + a[1][2] == 3
a.sum() with (int'(a[item.index][j])) == 3; // a[0][0] + a[1][0] == 3
// a[0][1] + a[1][1] == 3
// a[0][2] + a[1][2] == 3
Can you find one valid solution with values for the array that satisfy the constraints?
I understand now. Thank you!
