Write an assertion to check if a clock frequency is 40Mhz at every instance of the clock?
The Verification Academy forums is a place to ask questions and get help from fellow users to augment your understanding. It is not a chatBot. Please make an attempt to show some work so we can help you fill in areas where you are missing some fundamental understandings.
Dave is correct. We can help you, but don’t expect the work to be done for you.
Keep in mind that many questions and answers were provided and are available on the Internet. DO a search, and try AI. Also test your code with edaplayground.
Note that AI is not always correct.
