I have a UVM_REG model called my_reg_model. To do normal reads or writes, I would use my_reg_model.REG_NAME_REG0.write(uvm_reg_status,write_data);.
I want to add a task where the user can pass the name of the register (REG_NAME_REG0 in above example) and value to be written as input arguments, something like the below.
task base_seq::reg_write_task(string reg_name, bit [31:0] write_data);
`WRITE_REG(reg_name, write_data)
I tried using a macro, like below, but this results in error during elaboration as this evaluates to my_reg_model.reg_name.write( …) and “reg_name” is not a real register in the reg model.
`define WRITE_REG(reg_name,write_data) my_reg_model.reg_name
.write(uvm_reg_status, write_data);
What would be the correct way to do this? Any suggestions appreciated. Thank you!
