in this env read agent is active or passive?
what we are driving from driver side and what are the test cases require to verify multiplexer
In reply to NISHANG KHAMAR:
I don’t know how complex and configurable is, but it might be a overkill to employ the UVM for an easy design. If you want to do this it would be great to read the UVM-Userguide and some papers regarding UVM.
To answer your questions:
(1) if you want to drive a design you need an active agent.
(2) the test contains all the details you want to verify.
