Thanks, I have gone through the code and also ran it. My query is about taking decesion based on received response.
Please find below lines of code from given example:
From Driver Code
if(rsp.read_not_write == 1) begin
rsp.read_data = BUS.read_data; // If read - copy returned read data
rsp.error = BUS.error; // Copy bus error status
BUS.valid <= 0; // End the pin level bus transaction
seq_item_port.put(rsp); // put returns the response
From Sequence code:
start_item(req);
// The address is constrained to be within the address of the GPIO function
// within the DUT, The result will be a request item for a read or a write
assert(req.randomize() with {addr inside {[32'h0100_0000:32'h0100_001C]};});
finish_item(req);
get_response(rsp);
Simulation Messages:
# UVM_INFO top.sv(209) @ 2870: uvm_test_top.m_sequencer@@test_seq [seq_body]
# addr: 1000014
# write_data: 5fe70b99
# read_not_write: 1
# delay: 8
# error: 0
# read_data: 0
# UVM_INFO top.sv(209) @ 2990: uvm_test_top.m_sequencer@@test_seq [seq_body]
# addr: 1000018
# write_data: a7ecbab6
# read_not_write: 1
# delay: 1
# error: 0
# read_data: 38f93ae6
Here we have received read_data & error as a response from Driver in to a sequence. My point of query is about taking decision based on received response for driving next transaction.
Can sequence can be coded to wait for few clock cycle if rsp in error field is '1' ?
start_item(req);
finish_item(req);
get_response(rsp);
if(rsp.error==1)
wait for few clock cycle()
