What do we mean when we pass uvm_object_wrapper in the UVM environment for setting a default sequence to be executed in a specific phase? Usually we pass the “type” in the #(),
does it mean uvm_object_wrapper is the “type” of the sequence?
Example :
uvm_config_db #(uvm_object_wrapper)::set(this, “i_agt.sqr.reset_phase”, “default_sequence”, router_input_port_reset_sequence::get_type());
I see this usage so far only in env files, is there any other place where we could pass uvm_object_wrapper in #()?
According to the UVM Coding Guidelines, do not use reset_phase.
Second, you should not use the uvm_config_db to set the default_sequence for any phase. Instead, you should specify the default sequence to be executed during the run_phase of your base test. Then you can use a derived test to execute any other sequences you want to execute during run_phase. You can also use the factory to change the default sequence either via an override in the derived test of via the command line.
In reply to UVM_beginner:
Thanks for the suggestions. Could you please explain what uvm_object_wrapper means and when/where it should be used?
Please could you give an example for this? "Second, you should not use the uvm_config_db to set the default_sequence for any phase. Instead, you should specify the default sequence to be executed during the run_phase of your base test. "
Do you mean I should use “explicit” sequence execution? I am not sure if you mean “uvm_config_db” is the issue or “reset_phase” is the issue, or both?
