What does the field has value and name mean in IP-XACT?
To make register model from IP-XACT usually we do the implement XML as I know.
I came across the example as below, But I didn’t get the usage of value/name in field.
You can see the K0, K1, K2 and K3 Also 0,1,2 and 3 are implemented under a field.
Could you guide me please If a Field has value and name, how does it work? what is the purpose of them?
        <spirit:field>
            <spirit:name>frame_kind</spirit:name>
            <spirit:bitOffset>14</spirit:bitOffset>
            <spirit:bitWidth>2</spirit:bitWidth>
            <spirit:values>
              <spirit:value>0</spirit:value>
              <spirit:name>k0</spirit:name>
              <spirit:description>0</spirit:description>
            </spirit:values>
            <spirit:values>
              <spirit:value>1</spirit:value>
              <spirit:name>k1</spirit:name>
            </spirit:values>
            <spirit:values>
              <spirit:value>2</spirit:value>
              <spirit:name>k2</spirit:name>
            </spirit:values>
            <spirit:values>
              <spirit:value>3</spirit:value>
              <spirit:name>k3</spirit:name>
            </spirit:values>
            <spirit:vendorExtensions>
              <vendorExtensions:type>framek</vendorExtensions:type>
              <!--vendorExtensions:hdl_path>frame</vendorExtensions:hdl_path-->
            </spirit:vendorExtensions>
          </spirit:field>
In reply to UVM_LOVE:
Try asking here: IP-XACT Discussion - Accellera Systems Initiative Forums
