Hi, i am new to assertions, i could see in same cases , that its written (1,cnt),(1,cnt==signa_val)…etc…
What exactly does the 1 in the expression do?
In reply to adharshh:
I doubt you’ve seen exactly this code. What you probably saw is
(1,cnt=signa_val)
This is the sequence operation ( sequence_expr {, sequence_match_item} ) which means when the sequence_expr is true, execute the sequence_match_item. In the code you saw, the sequence_expr is 1, or always true, so it unconditionally executes the assignment to cnt.
This is explained further in section 16.10 of the IEEE 1800-2017 LRM
