Hello,
There are several tutorials that have this kind of code in the test:
env myEnv;
base_sequence seq;
myEnv = env::type_id::create("myEnv", this);
seq = base_sequence::type_id::create("seq");
seq.start(null);
I am not able to get this seq.start(null) to work. I get a run-time error:
UVM_FATAL @ 0: reporter@@seq [SEQ] neither the item's sequencer nor dedicated sequencer has been supplied to start item in seq
I read a comment saying start(null) starts the sequencer on a “default sequencer”. Is that an outdated concept in UVM? maybe related to `uvm_sequence_utils(seq,seqr)?
A related question about m_sequencer- it seems that m_sequencer gets initialized AFTER the sequence starts and is used to start more sequences on that sequencer. It can’t be accessed by the test because it is a “protected” property. Is that correct?
Is this the only way to start a sequence?
seq.start(myEnv.agent1.sequencer);
