In reply to karandeepsingh:
hey karandeep thanks for your response.
I set the sequencer from env. and get in virtual sequencer. I am using separate sequencer to handle virtual sequencer, but error are not going. I am attaching code please check it once.
//compile errors---------------------
class/and_virtual_seq.sv<13>:Invalid type ‘vitual_seqr’(separate sequencer which I am using )
class/and_virtual_seq.sv<13>:undefined variable ‘vitual_seqr’
class/and_write_test.sv<33>: near"and_write_inst" syntax error : unexpected IDENTIFIER expecting# class/and_write_test.sv<35>:near"and_reset_inst" syntax error : unexpected IDENTIFIER expecting #
//run time error---------------------
uvm_test_top.env_inst.agent_inst.seqr@@seq_inst [uvm_test_top.env_inst.agent_inst.seqr.seq_inst] Response queue overflow, response was dropped
385ns : Driver Send Transaction Request to Sequencer…
//warning
UVM_WARNING @ 0: uvm_test_top.env_inst.agent_inst.seqr@@seq_inst [uvm_sequence_base] Body definition undefined
//-------------code----------------------------------------
//-------class sequence------------------------------
class and_sequence extends uvm_sequence #(and_transaction);//parameterized with the type of the transaction
`uvm_object_utils(and_sequence) //uvm factory....registration
and_transaction tx; //sequence item
function new(string name =" "); //constructor
endfunction :new
task body();
endtask:body
endclass :and_sequence
class and_write_seq extends and_sequence;
`uvm_object_utils(and_write_seq)
// data members
and_transaction write_tx;
// constructor
function new (string name="");
endfunction : new
// body
task body();
// super.body();
`uvm_info("seq_body",$sformatf(" starting and_write_seq "),UVM_LOW)
write_tx = and_transaction::type_id::create("write_tx");
start_item(write_tx);
if(!write_tx.randomize() with {is_data==1; reset==0;})
`uvm_error("seq_body"," write_tx randomization failed")
finish_item(write_tx);
//wait for completion of burst
// get_response(write_tx);
`uvm_info("seq_body",$sformatf(" and_write_seq ends "),UVM_LOW)
endtask : body
endclass : and_write_seq
class and_reset_seq extends and_sequence;
`uvm_object_utils(and_reset_seq)
// data members
and_transaction reset_tx;
// constructor
endfunction : new
// body
task body();
// super.body();
`uvm_info("seq_body",$sformatf(" starting and_reset_seq "),UVM_LOW)
reset_tx = and_transaction::type_id::create("reset_tx");
start_item(reset_tx);
if(!reset_tx.randomize() with {reset==1; is_data==0;})
`uvm_error("seq_body"," reset_tx_req randomization failed")
finish_item(reset_tx);
// get_response(reset_tx);
`uvm_info("seq_body",$sformatf(" and_reset_seq ends "),UVM_LOW)
endtask : body
endclass : and_reset_seq
//base test-------------------------------------------
class my_base_test extends uvm_test;
`uvm_component_utils(my_base_test) //uvm factory…registration
my_env env_inst;
//and_sequence tx_seq;
//and_sequence seq_inst;
// Configuration objects
env_config env_config_inst;
function new(string name=“my_test”, uvm_component parent=null); //constructor
super.new(name,parent);
// env configuration
env_config_inst = env_config::type_id::create(“env_config”);
// Create the sequence
// seq_inst= and_sequence::type_id::create(“seq_inst”,this);
// Set the spi env config object
uvm_config_db #(env_config)::set(this, “*”, “env_config_inst”, env_config_inst);
// Create the enviornment
env_inst = my_env::type_id::create(“env_inst”, this);
endfunction:build_phase
endclass :my_base_test
//------------reset test-------------------------------------------
class my_reset_test extends my_base_test;
`uvm_component_utils(my_reset_test) //uvm factory…registration
// Methods
// Standard UVM Methods:
//function new(string name = “my_reset_test”, uvm_component parent = null);
//function void build_phase(uvm_phase phase);
//task run_phase(uvm_phase phase);
function new(string name=“my_reset_test”, uvm_component parent=null); //constructor
super.build(phase);
// uvm_info("test",$sformatf(" enter inside run_phase of PUT SEQUENCES ON SEQUENCER "),UVM_NONE);
uvm_info(“test”,$sformatf(" enter inside run_phase of my_reset_test "),UVM_NONE);
and_reset and_reset_inst = and_reset::type_id::create(“and_reset_inst”);
// We raise objection to keep the test from completing
phase.raise_objection(this, “Test Started”);
// start sequence put on the sequencer
and_reset_inst.start(null);
`uvm_info(“test”,$sformatf("and_reset seq starting "),UVM_NONE);
// #1000ns;
// uvm_report_info(“”,“Global Request”, UVM_LOW);
// global_stop_request();
// We drop objection to allow the test to complete
phase.drop_objection(this, “Test Finished”);
`uvm_info(“test”,$sformatf("and_reset seq ending "),UVM_NONE)
endtask :run_phase
function void end_of_elaboration();
print();
endfunction : end_of_elaboration
endclass :my_reset_test
//---------------------------write test
//------------test-------------------------------------------
class my_write_test extends my_base_test;
`uvm_component_utils(my_write_test) //uvm factory…registration
// Methods
//extern function new(string name = “my_write_test”, uvm_component parent = null);
//extern function void build_phase(uvm_phase phase);
//extern task run_phase(uvm_phase phase);
function new(string name=“my_write_test”, uvm_component parent=null); //constructor
super.build(phase);
`uvm_info(“test”,$sformatf(" enter inside run_phase of my_write_test "),UVM_NONE);
and_write and_write_inst = and_write::type_id::create(“and_write_inst”);
and_write_inst.start(null);
`uvm_info(“test”,$sformatf("and_write seq starting "),UVM_NONE);
// #1000ns;
`uvm_info(“test”,$sformatf("and_write seq ending "),UVM_NONE)
endtask :run_phase
print();
endclass :my_write_test
//----------Vitual sequencer--------------------------------
class virtual_seqr extends uvm_sequencer#(and_transaction);
`uvm_component_utils(virtual_seqr) //uvm factory....registration
function new(string name = "virtual_seqr", uvm_component parent=null); //constructor
endclass:virtual_seqr
//-----------------------------------------------Virtual sequences
class and_vseq_base extends uvm_sequence #(uvm_sequence_item);
`uvm_object_utils(and_vseq_base)
function new(string name = “and_vseq_base”);
// Virtual sequencer handles
virtual_seqr virtual_seqr_inst;
// Handle for env config to get to interrupt line
//and_env_config m_cfg;
// This set up is required for child sequences to run
task body;
// virtual_seqr_inst = virtual_seqr::type_id::create(“virtual_seqr_inst”);
if(!uvm_config_db #(virtual_seqr)::get(null, get_full_name(), “virtual_seqr”, virtual_seqr_inst)) begin
`uvm_error(“CONFIG_DB_ERROR”, “and sequencer not found”)
/* if(!uvm_config_db #(and_env_config)::get(null, {“uvm_test_top.”, get_full_name()}, “and_env_config”, m_cfg)) begin
`uvm_error(“body”, “Cannot find and_env_config”)
end */
endtask: body
endclass: and_vseq_base
// single and reset seq with random data
class and_reset extends and_vseq_base;
`uvm_object_utils(and_reset)
function new(string name = “and_reset”);
task body;
// issue reset seq
and_reset_seq reset_seq = and_reset_seq::type_id::create("reset_seq");
//call base virtual seq for sequencer's handle and cfg onject
// super.body;
//start tx and rx sequences
//at and_agent
reset_seq.start(virtual_seqr_inst);
join
endtask: body
endclass: and_reset
class and_write extends and_vseq_base;
`uvm_object_utils(and_write)
task body;
// issue reset seq
and_write_seq write_seq = and_write_seq::type_id::create("write_seq");
// virtual_seqr_inst=virtual_seq::type_id::create(.name(virtual_seq),.parent(this));
// super.body;
//start and_write sequences
//at and_agent
write_seq.start(virtual_seqr_inst);
join
endtask: body
endclass: and_write
//--------------------------------------------------------------end virtual_seq-------------
// Class env
class my_env extends uvm_env;
// Register class env in uvm factory
`uvm_component_utils(my_env)
// Create Instance of environment configuration
// Create Instance of agent
my_agent agent_inst;
// Create Instance of coverage
my_fc_sb my_fc_sb_inst;
// Create Instance of scoreboard
my_sb my_sb_inst;
// Construction Method
// Parent is the object in which environment is instantiated
// Build Method
function void build_phase( uvm_phase phase );
super.build_phase( phase );
// Construct environment configure
uvm_report_info(“”,“Creating Environment Configration…”, UVM_LOW);
env_config_inst = env_config ::type_id::create ( “env_config_inst” );
// Construct Agent
if ( env_config_inst.en_agent ) begin
uvm_report_info(“”,“Creating Agent…”, UVM_LOW);
agent_inst = my_agent::type_id::create( .name( “agent_inst” ), .parent( this ) );
// Construct Scoreboard
if ( env_config_inst.en_sb ) begin
uvm_report_info(“”,“Creating Scoreboard…”, UVM_LOW);
my_sb_inst = my_sb::type_id::create( .name( “my_sb_inst” ), .parent( this ) );
// Construct Coverage
if ( env_config_inst.en_fc_sb ) begin
uvm_report_info(“”,“Creating Subscriber…”, UVM_LOW);
my_fc_sb_inst = my_fc_sb::type_id::create( .name( “my_fc_sb_inst” ), .parent( this ) );
endfunction: build_phase
// Connect Method
function void connect_phase( uvm_phase phase );
super.connect_phase( phase );
// Connecting Agent and Coverage(TLM port to export)
// analysis port[agent] <—> analysis export[subscriber]
if ( env_config_inst.en_agent && env_config_inst.en_fc_sb)
uvm_report_info(“”,“Connecting Agent and Subscriber…”, UVM_LOW);
agent_inst.ap.connect( my_fc_sb_inst.analysis_export );
// Connecting Agent and scoreboard
if ( env_config_inst.en_agent && env_config_inst.en_sb)
uvm_report_info(“”,“Connecting Agent and Scoreboard…”, UVM_LOW);
agent_inst.ap.connect( my_sb_inst.analysis_export );
// Set up the agent sequencers as resources:
// uvm_config_db #(tx_rmmi_sequencer)::set(null, “", “tx_rmmi_sequencer”, m_tx_rmmi_agent.m_sequencer);
uvm_config_db #(virtual_seqr)::set(null, "”, “virtual_seqr”, agent_inst.virtual_seqr_inst);
endfunction: connect_phase
// End Of Elaboration Method
// In this method, call the print() method. This print()
// method will print the topology of the test
uvm_report_info(“”,“End_of_elaboration”, UVM_LOW);
// Start Of Simulation
function void start_of_simulation();
uvm_report_info(“”,“Start_of_simulation”, UVM_LOW);
uvm_report_info(“”,“Run Env”, UVM_LOW);
// Extract Method
function void extract();
uvm_report_info(“”,“Extract”, UVM_LOW);
// Check Method
function void check();
uvm_report_info(“”,“Check”, UVM_LOW);
// Report Method
function void report();
uvm_report_info(“”,“Report”, UVM_LOW);
//------------------------end env---------------------------------------
//------------------------------agent------------------------------------
//-----------------------agent-----------------------
// The agent contains sequencer, driver, and monitor (not included)
class my_agent extends uvm_component;
`uvm_component_utils(my_agent)
// Create Instance of analysis port
uvm_analysis_port #(and_transaction) ap;
// Create Instance of agent configuration
agent_config agent_config_inst;
// Create Instance of Sequencer
my_seqr seqr;
// Create Instance of Driver
my_driver drv;
// Create Instance of Monitor
my_monitor monitor;
// Build Method
// Construct analysis port
uvm_report_info(“”,“Creating Agent Analaysis Port…”, UVM_LOW);
ap = new(“ap”, this);
// Construct agent configuration
uvm_report_info(“”,“Creating Agent Configuration…”, UVM_LOW);
agent_config_inst = agent_config::type_id::create( .name( “agent_config_inst” ), .parent( this ) );
// Check agent configuration = ACTIVE
// Construct Driver and Sequencer
if ( agent_config_inst.active == UVM_ACTIVE )
uvm_report_info(“”,“Creating Driver and Sequencer…”, UVM_LOW);
drv = my_driver::type_id::create(“drv”, this);
seqr = my_seqr::type_id::create(“seqr”, this);
virtual_seqr_inst = virtual_seqr::type_id::create(“virtual_seqr_inst”, this);
// Construct Monitor
// Agent Configuration = ACTIVE OR PASSIVE
uvm_report_info(“”,“Creating Monitor…”, UVM_LOW);
monitor = my_monitor::type_id::create( .name( “monitor”), .parent( this ) );
//endfunction : build_phase
// Connection Method
// In UVM connect phase, we connect the sequencer to the driver.
// Connecting Agent and Monitor(TLM port - port)
// analysis port[agent] <—> analysis port[monitor]
uvm_report_info(“”,“Connecting Agent and Monitor…”, UVM_LOW);
ap = monitor.ap;
// Check agent configuration = ACTIVE &
// Connecting Driver and Sequencer (TLM port - export)
// seq_item_port[driver] <—> seq_item_export[sequencer]
if ( agent_config_inst.active == UVM_ACTIVE ) begin
uvm_report_info(“”,“Connecting Driver and Sequencer…”, UVM_LOW);
drv.seq_item_port.connect(seqr.seq_item_export);
endfunction :connect_phase
phase.objection.start(this);
and_sequence sequenc;
sequenc= and_sequencer::type_id::create(“sequenc”,this);
sequenc.start(seqr);
phase.objection.drop(this)
//--------------------------end agent------------------------------------------------
