I wanted to know whether uvm_tlm_analysis_fifo has a bounded size.
I am using it as part of my checker and I have quite heavy write cmds before starting to “get” the items from it.
when I am trying to search an item (which I know was written by prints in log) I am unable to track it.
**uvm_tlm_analysis_fifo#(T):
An analysis_fifo is a uvm_tlm_fifo#(T) with an unbounded size and a write interface.
You may want to use the following analysis_fifo methods to check/debug the FIFO status.
**virtual function int size()
**Returns the capacity of the FIFO-- that is, the number of entries the FIFO is capable of
holding. A return value of 0 indicates the FIFO capacity has no limit.
virtual function int used() Returns the number of entries put into the FIFO.
**virtual function bit is_empty()
**Returns 1 when there are no entries in the FIFO, 0 otherwise.
**virtual function bit is_full()
**Returns 1 when the number of entries in the FIFO is equal to its size, 0 otherwise.
