UVM_RESOURCE_DB SET AND GET
I am working on uvm_resource_db method, I set the configuration using set method i.e., uvm_resource_db #(string)::set(this,“”,“friend1”,“Ashwini Joshi”) in component TEST. I want to get the resource db using get method but I have a confusion here whether I will use get_by_type or get_by_name and I am not getting the correct syntax of these methods. Can you please provide the get methods syntax and guide me where I can use get_by_type and get_by_name methods. These two methods are like get methods as uvm_config_db or either Tasks or function. Please help me
Thanks in advance
Harshavardhan
In reply to Harsha vardhan:
The uvm_resource_db has some complexities and shouldn’t generally be used. Is there a reason you are trying to use it instead of the uvm_config_db?
In reply to cgales:
Hi cgales,
I am working on a project in that project they told me to use uvm_resource_db so, I am learning the uvm_resource_db and not able to get the complete information. please help me
Thanks in advance
Harshavardhan
Its for learning purpose so, if you can point me to any related resource. I’ll be grateful
Thanks in advance
Harshavardhan
If your project is using the uvm_resource_db instead of the uvm_config_db, you should advise that the best practice is to use the uvm_config_db.
Failing that, the UVM Reference will help understand the APIs available.
