can anyone over here can provide an example of uvm_reg_get_name function
Thank you
Thank you
In reply to harshareddy132:
My regsiter model has a register handle with the name ‘rxtx0’. apb_regs is my register model object.
See the code below:
task apb_rgm_default_seq::body();
`uvm_info(get_type_name(),"default sequence starting", UVM_MEDIUM)
apb_regs.get_registers(data_regs);
data_regs.shuffle();
foreach(data_regs[i]) begin
// Randomize register content and then update
if (data_regs[i].get_name() == "rxtx0")
`uvm_info(get_type_name(), "found rxtx0", UVM_MEDIUM)
