I started a “dphy_hs_sequence” in main_phase of a virtual sequencer. with rasie and drop objection in pre_body and post_body in this way;
virtual task pre_body();
uvm_phase phase;
super.pre_body();
phase = starting_phase;
if(phase!=null) begin
phase.raise_objection(this);
endtask: pre_body
I also start a “axi_snps_slave_sequence” in run_phase on another sequencer, without raise or drop objection, to serve as a AXI slave sequence. The axi_snps_slave_sequence is like this
class axi_snps_slave_sequence extends svt_axi_slave_base_sequence;
virtual task body();
`uvm_info("axi_snps_slave_sequence", "Entered ...", UVM_NONE)
/*add bvaid delay for each transaction*/
The actions in forever loop take effects, the bvaid has delay on waveform. However, the "
`uvm_info("zeku_axi_snps_slave_sequence", "Entered ...", UVM_NONE)
" did not print. Could you please tell my why body task skip the `uvm_info and directly jump into the for loop?
My test is like this:
class csi_dphy_delay_response_test extends csi_base_test;
function new (string name = "csi_dphy_delay_response_test",uvm_component parent = null);
endfunction : new
`uvm_component_utils(csi_dphy_delay_response_test)
uvm_config_db#(uvm_object_wrapper)::set(this, "csi_env.vsqr.main_phase", "default_sequence", dphy_hs_sequence::type_id::get());
uvm_config_db#(uvm_object_wrapper)::set(this, "csi_env.axi_slv.vip.slave[0].sequencer.run_phase", "default_sequence", axi_snps_slave_sequence::type_id::get());
