Dear All,
I’m trying to understand about backdoor access behavior.
But I’m confused the behavior of BACKDOOR access in write() and read() methods.
https://verificationacademy.com/cookbook/registers/backdooraccess
https://verificationacademy.com/cookbook/registers/backdooraccess#Tradeoffs_Between_Front_And_Backdoor_Accesses
If I use “UVM_BACKDOOR” read() and write() methods, It is also updated the all properties of register field object such as m_reset, m_mirrored, value, m_desired values? Or only just Read, Write the value in DUT by DPI without affecting the properties of register field object?
