1.Is it possible to access the inbuilt response queue and request queue which is there inside a sequencer if yes then is it possible to take a handle of that queue and access the response in another UVM component class.
2.i want to store the data coming from a slave side to the master driver side and from driver it will send that data as a response to the sequence and from this sequence I want to take this response data which is received in this sequence class and store it in a different queue which is defined in another UVM component class…is it possible?.. according to me what we can do is we can take a handle of this sequence class inside that component where we want to store this response in a queue and using this sequence handle class we can access the response and store it in a different queue…let me know whether this will works or not
