I am trying to override the Configuration objects inside env, but they don’t seem to be overriding… I am not sure, if I am missing something here…
Here’s code:
program top;
`include "uvm_macros.svh"
class cfg extends uvm_object;
rand bit [1:0] i_type;
`uvm_object_utils_begin(cfg);
`uvm_field_int (i_type, UVM_ALL_ON|UVM_DEEP)
`uvm_object_utils_end
function new(string name="cfg");
endfunction : new
class c_0 extends cfg;
`uvm_object_utils(c_0);
constraint i_type_c { i_type == 2'b00; }
function new(string name="cfg_0");
endfunction : new
class c_1 extends cfg;
`uvm_object_utils(c_1);
constraint i_type_c { i_type == 2'b01; }
function new(string name="cfg_1");
endfunction : new
class c_2 extends cfg;
`uvm_object_utils(c_2);
constraint i_type_c { i_type == 2'b10; }
function new(string name="cfg_2");
endfunction : new
class c_3 extends cfg;
`uvm_object_utils(c_3);
constraint i_type_c { i_type == 2'b11; }
function new(string name="cfg_3");
endfunction : new
class env extends uvm_env;
`uvm_component_utils(env);
cfg m_cfg;
function new(string name="env", uvm_component parent=null);
super.new(name,parent);
endfunction : new
if (uvm_config_db#(cfg)::get(get_parent(), get_name(), "cfg", m_cfg)) begin
`uvm_info("build_phase", "Using test case provided cfg", UVM_LOW)
m_cfg.print();
else begin
`uvm_info("build_phase", "External cfg not provided for cfg, creating default cfg.", UVM_LOW)
m_cfg = cfg::type_id::create("cfg");
m_cfg.print();
class test extends uvm_test;
cfg my_c0;
cfg my_c1;
cfg my_c2;
cfg my_c3;
env my_env[4];
`uvm_component_utils(test)
function new(string name="test", uvm_component parent=null);
endfunction : new
// factory.set_inst_override_by_name( "cfg",
// "my_c2",
// "uvm_test_top.my_env[2]");
set_inst_override_by_type("my_env[0].cfg",
cfg::get_type(),
c_0::get_type());
set_inst_override_by_type("my_env[1].cfg",
cfg::get_type(),
c_1::get_type());
set_inst_override_by_type("my_env[2].cfg",
cfg::get_type(),
c_2::get_type());
set_inst_override_by_type("my_env[3].cfg",
cfg::get_type(),
c_3::get_type());
my_c0 = cfg::type_id::create("my_c0");
my_c1 = cfg::type_id::create("my_c1");
my_c2 = cfg::type_id::create("my_c2");
my_c3 = cfg::type_id::create("my_c3");
uvm_config_db#(cfg)::set(this, "my_env[0]", "cfg", this.my_c0);
uvm_config_db#(cfg)::set(this, "my_env[1]", "cfg", this.my_c1);
uvm_config_db#(cfg)::set(this, "my_env[2]", "cfg", this.my_c2);
uvm_config_db#(cfg)::set(this, "my_env[3]", "cfg", this.my_c3);
my_env[0] = env::type_id::create("my_env[0]", this);
my_env[1] = env::type_id::create("my_env[1]", this);
my_env[2] = env::type_id::create("my_env[2]", this);
my_env[3] = env::type_id::create("my_env[3]", this);
function void end_of_elaboration_phase(uvm_phase phase);
super.end_of_elaboration_phase(phase);
factory.print();
class my_test extends test;
`uvm_component_utils(my_test)
function new(string name="my_test", uvm_component parent=null);
endfunction : new
run_test("my_test");
endprogram
Synopsys Outputs:
UVM_INFO @ 0: reporter [RNTST] Running test my_test…
UVM_INFO top.sv(60) @ 0: uvm_test_top.my_env[0] [build_phase] Using test case provided cfg
Name Type Size Value
my_c0 cfg - @470 ← Here:: Type ‘cfg’ should have been ‘c_0’
i_type integral 2 'h0
UVM_INFO top.sv(60) @ 0: uvm_test_top.my_env[1] [build_phase] Using test case provided cfg
my_c1 cfg - @471 ← Here:: Type ‘cfg’ should have been ‘c_1’
UVM_INFO top.sv(60) @ 0: uvm_test_top.my_env[2] [build_phase] Using test case provided cfg
my_c2 cfg - @472 ← Here:: Type ‘cfg’ should have been ‘c_2’
UVM_INFO top.sv(60) @ 0: uvm_test_top.my_env[3] [build_phase] Using test case provided cfg
my_c3 cfg - @473 ← Here:: Type ‘cfg’ should have been ‘c_3’
Factory Configuration (*)
Instance Overrides:
Requested Type Override Path Override Type
cfg uvm_test_top.my_env[0].cfg c_0
cfg uvm_test_top.my_env[1].cfg c_1
cfg uvm_test_top.my_env[2].cfg c_2
cfg uvm_test_top.my_env[3].cfg c_3
No type overrides are registered with this factory
All types registered with the factory: 44 total
(types without type names will not be printed)
Type Name
c_0
c_1
c_2
c_3
cfg
env
my_test
test
(*) Types with no associated type name will be printed as
— UVM Report Summary —
** Report counts by severity
UVM_INFO : 5
UVM_WARNING : 0
UVM_ERROR : 0
UVM_FATAL : 0
** Report counts by id
[RNTST] 1
[build_phase] 4
Look out for “Here” in the results. I am expecting the type to change to c_0/1/2/3.
