UVM Low Power Base Class Package
Is there a UVM Low Power Base class and application Package available as it is available in VMM ?
Normally How do we develop Power Aware Verification environment in UVM methodology? Any reference document will be helpful
Hello Debashis
I know its been 5.5 long years but the solution is now available as UPVM.
If you are still interested, Silicon Interfaces announces Power Verification™ open source UPVM Low Power Class Library as extension to UVM Package
Please permit me to share this announcement with rider that the purpose is that we would like to explore services projects around this techniques for your UVM and Low Power requirements.
Industry tends to incorporate Power Architecture either in conjunction with or in sequence to functional verification using different languages, many times with different team members using different tools, and divergent approaches leading to potential errors, almost a fourth dimension to our strategy.
The Design team seems to be following a parallel path (even if in pipeline mode there is a time gap) with respect to the Methodologies based test bench and Power Architecture, including Unified Power Formats (UPF). Both are fundamental to IP and ASIC verification requirements, especially in the power-saving mobile world.
Why have two sets of engineering for verification and low power? Go green! Low Power helps batteries dissipate slower! Then why waste power with separate Verification and UPF simulation cycles? And burn the midnite oil learning power formats!
It would be more efficient to do Methodologies-based Functional Verification and Coverage interspersed with Low Power Implementation.
With Silicon Interfaces UPVM the Design/Verification Engineer interleaves functional verification and low power in existing methodologies UVM!
Based on these techniques, Silicon Interfaces now has the industry’s first integrated Power Verification deployable service platform with near-zero ramps in timelines.
Silicon Interfaces® requests you to register for a Presentation + Demo PredCast™ Online on Low Power Classes as extension to UVM Package Library (Silicon Interfaces welcomes you Presentation + Demo : PredCast™ online on Low Power Classes as extension to UVM Package Library on Tue, 30th May 2023 at 08:30 pm IST)
If you are not able to attend the PredCast™ please let us know and we can schedule a one-on-one online meeting.
We look forward to hearing from you!
