Hi Friends,
I have connected monitor port to scoreboard port. After that i am getting compile error.
Error-[ICTTFC] Incompatible complex type usage
…/…/…/…/…/tb/UVM/top/env/env.sv, 133
Incompatible complex type usage in task or function call.
The following expression is incompatible with the formal parameter of the
function. The type of the actual is ‘class
uvm_pkg::uvm_analysis_export#(class $unit::sv_transaction)’, while
the type of the formal is ‘class uvm_pkg::uvm_port_base#(class
uvm_pkg::uvm_tlm_if_base#(class
sv_package::sv_transaction,class
sv_package::sv_transaction))’. Expression:
this.top_sb.axi_rd_analysis_export
Source info:
this.slv_agnt.slave_monitor_inst.slv_mon_ap.connect(this.top_sb.axi_rd_analysis_export)
I am sharing code below.
env.sv file:
`uvm_info(“connect_phase”, “Entering into env connect phase”, UVM_LOW)
slv_agnt.slave_monitor_inst.slv_mon_ap.connect(top_sb.axi_rd_analysis_export);
Monitor file.sv (Port declared):
uvm_analysis_port #(sv_transaction) slv_mon_ap;
scoreboard (Port declared):
uvm_analysis_export #(sv_transaction) axi_rd_analysis_export ;
//Sequence item class
class sv_transaction extends uvm_sequence_item ;
Env file:
/** Construct the top scoreboard */
top_sb = top_scoreboard::type_id::create(“top_sb”, this);
Agent :
class slave_agent extends uvm_agent ;
`uvm_component_utils(slave_agent)
slave_monitor slave_monitor_inst ;
slave_monitor_inst = slave_monitor::type_id::create(“slave_monitor_inst”, this) ;
Can you please anyone help me on this.
Regards,
Raj
