Hi guys, I have a basic question. A UVM example on one of the sites defines the sequence class as follows, (question is indicated by arrows):
class mem_sequence extends uvm_sequence#(mem_seq_item);
`uvm_sequence_utils(mem_sequence,mem_sequencer)
//Constructor
function new(string name = "mem_sequence");
virtual task body();
req = mem_seq_item::type_id::create("req"); ///<------------------------------------------ Here he creates the req and puts in factory registry isn't it?
wait_for_grant();
req.randomize();
send_request(req);
wait_for_item_done();
then he seems to access it in driver class without even declaring its type?
class mem_driver extends uvm_driver #(mem_seq_item);
// Virtual Interface
virtual mem_if vif;
`uvm_component_utils(mem_driver)
//uvm_analysis_port #(mem_seq_item) Drvr2Sb_port;
// Constructor
endfunction : new
if(!uvm_config_db#(virtual mem_if)::get(this, "", "vif", vif))
`uvm_fatal("NO_VIF",{"virtual interface must be set for: ",get_full_name(),".vif"});
endfunction: build_phase
// run phase
seq_item_port.get_next_item(req);// <-------------------------------------------------------------how was he able to access the req without even declaring it.?
//respond_to_transfer(req);
drive();
seq_item_port.item_done();
endtask : run_phase
// drive
virtual task drive();
req.print();
`DRIV_IF.wr_en <= 0;
`DRIV_IF.rd_en <= 0;
@(posedge vif.DRIVER.clk);
`DRIV_IF.addr <= req.addr;
if(req.wr_en) begin
`DRIV_IF.wr_en <= req.wr_en;
`DRIV_IF.wdata <= req.wdata;
//$display("\tADDR = %0h \tWDATA = %0h",req.addr,trans.wdata);
if(req.rd_en) begin
`DRIV_IF.rd_en <= req.rd_en;
req.rdata = `DRIV_IF.rdata;
// $display("\tADDR = %0h \tRDATA = %0h",trans.addr,`DRIV_IF.rdata);
$display("-----------------------------------------");
endtask : drive
endclass : mem_driver
I know the factory has something to do with it.
Can someone help explain this?
