I get an error:
The object at dereference depth 1 is being used before it was
constructed/allocated.
Please make sure that the object is allocated before using it.
it failed on line in file:
@(negedge env.spi_agnt.spi_sigs.mon_cb.spi_ce);
I have a file for interfaces,
There I send the interface :
uvm_config_db #(virtual spir180_if)::set(null, "uvm_test_top.env", "spir180_sigs", spir180_sigs);
and in my monitor ,I get the interface in build phase:
if (! uvm_config_db #(virtual spir180_if) :: get (this, "", "spir180_sigs", spir180_sigs)) begin
`uvm_error (get_type_name (), "spir180_if interface not found")
What is not good that it falls on this error?
