Can anyone help me what wrong I am doing here, as a result, there is a null access while using the config_db get.
The syntax used for setting the virtual interface:
svt_jesd204_if jesd204_rx_if4;
genvar n;
generate
for(n=0;n<`SVT_JESD204_MAX_LINK;n=n+1) begin
uvm_config_db#(svt_jesd204_vif)::set(uvm_root::get(), “uvm_test_top.env.jesd204_env_inst”,$sformatf(“jesd204_rx_if[%0d]”,n), jesd204_rx_if[n]);
uvm_config_db#(svt_jesd204_vif)::set(uvm_root::get(), “uvm_test_top.env.jesd204_env_inst”,$sformatf(“jesd204_tx_if[%0d]”,n), jesd204_tx_if[n]);
endgenerate
// Syntax used for getting the virtual interface
for(int ii=0; ii<4; ii++) begin
if(!(uvm_config_db#(svt_jesd204_vif)::get(this,“uvm_test_top.env.jesd204_env_inst”,$sformatf(“jesd204_rx_if[%0d]”,ii),jesd204_rx_if[ii]))) begin
`uvm_error(get_full_name(), $psprintf(“jesd204_rx_if[%0d] is not found in the config DB, have you set it, plz cross check??”, ii))
