HI Form,
I have two agents which from one env ,
but the problem is
agent1 driver should preload the data to other drivers memory(agent2) .how could i access this task,
kindly guide,
thanks,
Gowtham.
HI Form,
but the problem is
kindly guide,
thanks,
Gowtham.
class driver1 extends uvm_driver;
// it has file operation were it opens and reads the data//
class slave driver extends uvm_driver;
logic [7:0] mem [*];
were this reads the data and send back to master,
now in my driver1 should back load the data to memory of slave driver//
can suggest me how can i achieve this,
thanks,
Gowtham.
In reply to P.Gowtham Santosh:
Could you please explain in some more detail what you want to do. Currently it does not look like you need 2 agents.
