Hi all,
I want to create a top-level uvm_reg_block wrapper which instantiates multiple block-level uvm_reg_blocks for different interfaces, hence I need to set separate sequencer for each instance of the block-level uvm_reg_block. I tried this:
// TOP LEVEL REG BLOCK
class top_level_reg_block extends uvm_Reg_block;
virtual function void build()
this.default_map = create_map (…);
this.block_a = block_a_type::type_id::create(block_a);
this.block_a.configure(this);
this.block_a.build();
this.block_a.lock_model();
this.default_map.add_submap(this.block_a.default_map, `BLOCK_A_OFFSET);
this.block_b = block_a_type::type_id::create(block_b);
this.block_b.configure(this);
this.block_b.build();
this.block_b.lock_model();
this.default_map.add_submap(this.block_b.default_map, `BLOCK_B_OFFSET);
endfunction: build
Env File :
top_level_reg_block rgb;
/// Build phase
rgb = top_level_reg_block::type_id:create(“rgb”);
rgb.build();
rgb.default_map.set_auto_predict(1);
rgb.default_map.set_base_addr(`BASE_ADDR);
rgb.default_map.reset();
rgb.reset();
rgb.lock_model();
//// Connect phase
rgb.block_a.default_map.set_sequencer (seq_a, adp_a);
rgb.block_b.default_map.set_sequencer (seq_b, adp_b);
I get FATAL Error whenever I try to access a register belongs to any of above Reg_block i.e. block_a or block_b.
UVM_FATAL @ 100.000 ns: reporter@@default_parent_seq [SEQ] neither the item’s sequencer nor dedicated sequencer has been supplied to start item in default_parent_seq
Further, I tried by setting the following:
rgb.default_map.set_sequencer(seq_a, adp_a);
This time it works but it always issues the requests on the seq_a.
I want to set both the sequencers so that it automatically determines which sequencer it needs to issue the request.
Any suggestions, please.
