In following code :
`uvm_analysis_imp_decl(_in)
class my_scb extends uvm_scoreboard;
`uvm_component_utils(my_scb)
uvm_analysis_imp_in #(mon_tr, my_scb) in_export;
uvm_analysis_port #(scb_tr) scb_port;
uvm_analysis_export #(scb_tr) scb_export;
uvm_tlm_analysis_fifo #(scb_tr) scb_fifo;
endfunction: new
scb_port = new("scb_port", this);
scb_export = new("scb_export", this);
scb_fifo = new("scb_port", this);
endfunction: build_phase
scb_port.connect(scb_export);
scb_export.connect(fifo.analysis_export);
endfunction: connect_phase
task run();
scb_tr my_scb_tr = new();
fifo.get(my_scb_tr);
`uvm_info("", "Got new scb tr", UVM_NONE);
endtask: run
virtual function void write(mon_tr in_tr;);
mon_tr my_mon_tr;
my_tr.copy(in_tr);
convertMon2ScbTr(my_mon_tr, my_scb_tr); // converting tr
scb_port.write(my_scb_tr);
`uvm_info("", "Write to port done", UVM_NONE);
endfunction: write
endclass: my_scb
Monitor is connected to scoreboard. And sending mon_tr.
I am seeing one peculiar case where prints are as follows on SAME TIME stamp:
Write to port done
Got new scb tr
Got new scb tr
Point to be noted, “Got new scb tr” are coming at same time stamp.
Here if I print scb tr along with “Got new scb tr” message, in first print tr data is incorrect while second print gets correct data.
I aren’t sure is this simulator issue or I am missing something very trivial in code.
