UVM objects such as sequence_items are designed to be passed around the hierarchy from one component to another using the various transport mechanisms. Due to this use model and the fact that several components might be maintaining a pointer to the same UVM object (a configuration object, for example), there is no concept of a ‘parent’ for an object.
If you want something to exist at a fixed point in the UVM hierarchy, then you should use a UVM component.
