Many of the examples I see related to configuration follow the following pattern:
class ...
// Component Members
// The environment class
spi_env m_env;
// Configuration objects
spi_env_config m_env_cfg; // inside has agent handles
apb_agent_config m_apb_cfg;
spi_agent_config m_spi_cfg;
// Register map
spi_register_map spi_rm;
endclass: spi_test_base
// Build the env, create the env configuration
// including any sub configurations and assigning virtural interfaces
function void spi_test_base::build_phase( uvm_phase phase );
m_env_cfg = spi_env_config::type_id::create("m_env_cfg");
// Register map - Keep reg_map a generic name for vertical reuse reasons
spi_rm = new("reg_map", null);
m_env_cfg.spi_rm = spi_rm;
m_apb_cfg = apb_agent_config::type_id::create("m_apb_cfg");
configure_apb_agent(m_apb_cfg);
if( !uvm_config_db #(virtual apb_if)::get(this, "" , "APB_vif",m_apb_cfg.APB) ) `uvm_error(...)
m_env_cfg.m_apb_agent_cfg = m_apb_cfg;
Why does the class have member handles for the (nested) env config AND configs for each of the agents IN the env?
What is wrong with:
class ...
spi_env m_env;
m_env_cfg.spi_rm = new("reg_map", null);
It just always confuses me to see 2 members that in my opinion are identical for the test: m_env_cfg.m_apb_agent_cfg and m_apb_cfg
Note: I am ok with the env then creating seperate config objects, it is just in the test example that the confusion arises.
