I would like to suppress as specifically as possible some warnings in uvm_reg.svh.
E.g. the warning
`uvm_warning("RegModel", {"Unable to locate field '",name,
"' in register '",get_name(),"'"})
in get_field_by_name.
I am considering using
+uvm_set_action=<comp>,<id>,<severity>,<action>
But wonder what
comp
should be in this case?
Any other method? The above one isn’t very specific as it will suppress all warnings in uvm_reg.svh I believe…
chr_sue
February 18, 2017, 4:30pm
2
In reply to Nico75 :
comp is the component in which you want to supress this warning. See the UVM Reference Manual example:
+uvm_set_action=uvm_test_top.env0.*,ALL ,UVM_ERROR,UVM_NO_ACTION
In reply to chr_sue :
UVM registers or reg blocks are uvm_objects, no uvm_components, no?
chr_sue
February 18, 2017, 7:03pm
4
You are right. But I believe you are looking into the wrong direction. What you can do is writing your own report catcher and demoting the UVM_WARNING, i.e. changing it to UVM_INFO.
But how do I then link it to the UVM source code?
chr_sue
February 18, 2017, 9:51pm
6
You have to implement your own report catcher by extending the base class uvm_report_catcher.
This requires your own catch method.
Yes, but then I need to add it to each uvm_reg in some way.
I assume for every uvm_reg I could do someting like:
uvm_report_cb::add(reg1, demoter);
uvm_report_cb::add(reg2, demoter);
etc...
But that is quite some work. I am not even sure I can pass a uvm_object to add?
Perhaps I could use something as follows:
uvm_report_cb::add_by_name("my_reg_model.*", demoter);
so that it gets added to everything in my registermodel (very brute force though)
chr_sue
February 19, 2017, 3:50pm
8
It is something like this:
function void end_of_elaboration_phase(uvm_phase phase);
catcher_h = new("catcher_h");
uvm_report_cb::add(null, catcher_h);
where the first argument in the add method is the report object or null for all objects.
Additionally you have to implement your own catcher class.
class my_report_catcher extends uvm_report_catcher;
function new (string name = "");
function action_e catch;
uvm_severity severity = get_severity();
string id = get_id();
uvm_action action = get_action();
string message = get_message();
int verbosity = get_verbosity();
if (severity == UVM_WARNING)
set_severity(UVM_INFO);
if (severity == UVM_ERROR)
return CAUGHT;
return THROW;
is using ‘null’ a bit drastic? I would need to make sure I filter correctly in the catch method.
chr_sue
February 19, 2017, 6:44pm
10
I’d say in your case yes. My intention was to show the options.
