I was using starting phase to raise and drop objections in my uvm_env. But when I migrated to UVM1.2. It was working fine ( was able raise and drop
objection) but for some testcases it was raising the objection (for my sequence but not dropping the objection and simulation was also completed with
PASS banner.
The solution for this I found out was to use get_starting_phase() instead of starting phase.It behave correctly as earlier.
Hello All ,
PASS banner.
Any suggestions on this …?
Could you please show the code where you are raising and dropping your pbjections?
Ther eis achange from UVM-1-1 to UVM1.2 dealing with the starting phase. When migrationg your code you have to consider this.
Hello All ,
PASS banner.
