Setting and pulling config object for a child component
Lets say I have a component CompA, and object CompA_cfg.
Later I extend both of these:
CompA ->CompB
CompA_cfg->CompB_cfg
Both compA and compB peform a ‘get’ configuration pull in their build_phases.
Assume I want to instantiate my new ‘CompB’ and it’s new config object in the env.
Is it possible to satisfy those configuration pulls by doing a SINGLE configuration set in the environment?
CompB my_comp;
task build_phase();
  uvm_config_db #( CompB_cfg )::set( this, my_comp, "cfg", cfg.compb_cfg_obj ); <----
This satisfies the child component, but the parent (compA) can no longer find it’s configuration in the database.
If I want it to work, I also have to add this to build_phase:
uvm_config_db #( CompA_cfg )::set( this, my_comp, "cfg", cfg.compb_cfg_obj );
In reply to bmorris:
You can have a single set() by doing
uvm_config_db #( CompA_cfg )::set( this, my_comp, "cfg", cfg.compb_cfg_obj ); <----
You can have a single get() in your CompA base clase, but CompB will need $cast the object to CompB_cfg variable.
Also, you should not be constructing both CompA_cfg and CompB_cfg objects. Use the factory to override the cfg object creation.
BTW, I’ve said many times before, I wish people would stop using “child” to refer to an extended class.
"You can have a single get() in your CompA base clase, but CompB will need $cast the object to CompB_cfg variable. "
Got it. Thanks.
"Also, you should not be constructing both CompA_cfg and CompB_cfg objects. Use the factory to override the cfg object creation. "
I don’t currently construct both, just CompB_cfg. I see what you mean though. I could, in my env config have CompA_cfg instead. Then, in my test do an override, build env, then cast cfg.comp_cfg to compB_cfg. Then I can configure the additional properties of the extension.
I implemented the factory and casting technique, and finally got that working. That having been said…
I have a test base class I use that looks like:
virtual class test_BASE #(type ENV_TYPE=int, CFG_TYPE=int) extends uvm_test ;
  ENV_TYPE env;   <------
  CFG_TYPE cfg;   <------
This is my only class I don’t modify using the factory; it uses parameters. I did this because I can’t “create” the ‘cfc’ and ‘env’ objects if they are types uvm_component, and uvm_object.
Furthermore, I’d have to do an ‘instance’ override with a static path name in a test_BASE extension.
Thoughts?
