Receiving DUT internal signals into test through uvm_config_db
Hi
I am facing an issue with uvm_config_db and need a clarification regarding the same. I have a requirement of probing the RTL and checking few signals in my test. I have assigned the signals to a tb bit and sent the bit using uvm_config_db. Below is the relevant part of the code which I wrote in my tb.
bit axi2apb_default_slave_intr;
axi2apb_default_slave_intr = v5cpe_top_u.v5cpe_core.periphss.APB_DSLAVE.int_out;
uvm_config_db#(bit)::set(uvm_root::get(),“*”,“axi2apb_default_slave_interrupt”,axi2apb_default_slave_intr);
I am seeing that the value I receive through the variable (axi2apb_default_slave_intr) is not changing with time.
My question: In this case, is a pointer to the variable axi2apb_default_slave_intr passed through uvm_config_db or is it the value of axi2apb_default_slave_intr at the start of build phase being sent. (I am getting this signal in my test during the build phase)
Thanks in advance
Jeevan
You are only passing the value in both the uvm_config_db#bit::set() and in the assignment to axi2apb_default_slave_intr.
Please see my DVCon paper on probing DUT signals. http://events.dvcon.org/2012/proceedings/papers/01P_3.pdf
