Range must be bounded by constant expressions
for(int i =0 ;i<size;i++) begin
    if(i == 0) begin
      byte_que[i] = index;
    else if (i == 1) begin
      if(index == 0) begin
        byte_que[i] = command;
      else
        byte_que[i] = address_data[7:0];
    else begin
      byte_que[i] = address_data[i*8+7:i*8]; // I am getting error in this line
while executing the code I am getting the following error : -
i2c_hl_driver.svh(99): Range must be bounded by constant expressions
can anyone help me how to resolve this one
In reply to lalithjithan:
The key question is: what is ‘size’? It cannot be a variable.
size is a logic type,like below : -
logic [2:0] size;
if(cmd == 0)
size = 2;
else
size = 3;
    if(i == 0) begin
      else
    else begin
As I said you cannot use a variable for this. size has to be a parameter.
If you want to extract byte ‘i’, you can do the following:
byte_que[i] = address_data[i*8 +: 8];
This means slice 8 bits starting from index ‘i*8’. The number of bits you slice (in this case 8) has to be a constant. The starting position can be a variable.
Why we can’t use variable for this?
@lalithjithan: Maybe the expression is out of boundary of address_data. Why is the width of address_data?
In reply to chris_le:
the width of address_data is 32 bit
logic [31:0] address_data
In reply to Tudor Timi:
Hi,i tried
but i getting the following results :-
i am passing address_data as = 32’h123456
but my queue has : -
byte_que[0] = 4
byte_que[1] = 56
byte_que[2] = 12
byte_que[3] = 0
byte_que[4] = x
I meant you can noz use variables together with this line of code:
Because the slice is not constructed by a constant expression.
No idea what you’re doing to get those results, but the following example works as expected:
module test;
  byte unsigned byte_que[4];
  bit [31:0] address_data = 32'h123456;
    foreach (byte_que*)
    $display("%p", byte_que);
You get [i]'{'h56, 'h34, 'h12, 'h0}* printed.
module test;
foreach (byte_que*)
thank you Its working now.
