Hi ,
The UVM LRM 18002-2017 mentions the following for function add_submap
The number of consecutive physical addresses occupied by the submap depends on
the number of bytes in the physical interface that corresponds to the submap,
the number of addresses used in the submap, and
the number of bytes in the physical interface corresponding to this address map.
By “number of bytes in the physical interface that corresponds to the submap”
I believe it means the 3rd argument ’ n_bytes ’ to create_map for sub_map .
Similarly “number of bytes in the physical interface corresponding to this address map” points to the 3rd argument ’ n_bytes ’ to create_map for parent map .
I am not able to get the following
- the number of bytes in the physical interface corresponding to this address map
- the number of addresses used in the submap
How does ’ n_bytes ’ passed to create_map for parent address map impact
The number of consecutive physical addresses occupied by the submap ?
Let’s take an example ::
// [1] Within build() of CSR with 10 registers which in itself is sub_block
// Create 10 registers and call their respective build() function first
default_map = create_map( "default_map" , 'h0 , 4 , UVM_LITTLE_ENDIAN , 1 ); // 4-byte physical interface
default_map.add_reg( reg1 , 'h0 , "RO" );
default_map.add_reg( reg2 , 'h4 , "RW" );
default_map.add_reg( reg10, 'd36 , "RW" );
// [2] Within build() of Parent block which has above CSR as sub-block
// create CSR Sub-block and call it's build() here
default_map = create_map( "default_map" , 'h0 , 8 , UVM_LITTLE_ENDIAN , 1 ); // 8-byte physical interface
default_map.add_submap( CSR.default_map , 'h100 );
So how does one calculate the number of consecutive physical addresses occupied by the CSR submap ?
