Overriding a parameter
I need to override the parameter value of a parameterized uvm_component. Is this possible at all? I’ve tried several ways and failed in all of them. I can’t pass a variable/config field to the parameter while creating the component.
eg: A#(xyz)::type_id::create - This won’t work as I need to declare the type of A with the parameter.
I’m almost certain that the answer will be a NO, but just wanted someone to confirm this:
Can we do this for class A which has an integer parameter. I’m getting an FCTTYP error with this.
A#(4)::type_id::set_type_override(A#(5)::get_type())
Any help with this is appreciated. Thanks!
When you are using parameterized components and objects, make sure that you use the corresponding `uvm_*_param_utils macros and not the normal ones:
class my_param_component#(int WIDTH=32) extends uvm_component;
  `uvm_component_param_utils(my_param_component#(WIDTH))
In reply to cgales:
I did that. The issue I’m having is that I don’t want to hardcode the value of the parameter at the time of the object creation. Instead, I want it to be something like a config bit.
eg: I’m trying to do this:
 obj_A = class_A#(xyz_cfg.width)::type_id::create();
You can’t override a class parameter (or any parameter in SystemVerilog for that matter) with a dynamic variable. It must be another parameter, a literal constant, or some expression containing only these.
There are a few ways to achieve something close to what you are looking for if you can elaborate all the possible values of values that could be selected. (i.e. xyz_cfg.width could be 8,16,32,64)
You can create an associative array of proxy classes indexed by the elaborated values, then select the element you want to override with
class class_A #(int WIDTH) extends common_base;
uvm_object_wrapper class_A_proxies[int] = '{
                 5:class_A#(5)::get_type(),
                 8:class_A#(8)::get_type(),
                 16:class_A#(16)::get_type()
commmon_base::type_id::set_type_override(class_A_proxies[xyz_cfg.width]);
See my popular DVcon paper for more details about parameters, constants, proxies and why you need a common_base class.
Another mechanism is to use a string lookup as described in another blog post of mine.
Thanks for the pointers, Dave. Is it possible to change the value of the parameter in an extended class and then override the class using a plusarg?
eg:
class A;
   parameter int WIDTH = 8;
class A1 extends A;
    parameter int WIDTH = 16;
run the test with +uvm_set_type_override=A,A1
In reply to itsmyturn:
Extending a class with another parameter does not override the parameter inside the base class, it just adds another parameter.
What you can do is
class A extends uvm_object;
`uvm_object_utils(A)
// put anything that is not dependent on the WIDTH in this class
class B #(int width) extends A;
// no factory registration
class B16 extends B#(16);
`uvm_object_utils(B16)
run test with +uvm_set_type_override=A,B16
Thanks a lot, Dave. Do we need 3 layers here? Can’t we just override A with B#(16)?
You can use 2 layers if you use the A::type_id::set_type_override(B#(16)) method, or if you use one of the mechanisms I showed above. You can only use the +uvm_set_type_override plusarg method with 2 layers if there is a string name associated with a class type you want to override. The UVM macros don’t register strings names for parameterized classes, but you can do that yourself explicitly.
Don’t you need a tick in the uvm macro calls? Also, it appears your post is missing eol’s.
Fixed. Thanks. That was a formatting problem when we migrated the forums to a new platform.
