I am new to UVM and was trying the set_inst_override_by_type method. the first grandchild object is created using the factory create method, so, I it should be supporting these two overrides as far as I know. When I’m using “set_type_override_by_type” then the code is working as it should and printing “I’m the new grandchild” when e.c1.gc1.display() is called in the report_phase of test class. But when I use set_inst_override_by_type to just override e.c1.gc1, the override is not happening and display function of the grandchild is being called instead of the overriding display function of the newgrandchild class. The same can be seen in the topology that I’m printing in the same reporting phase. I’ve attached my full code which I was trying on EDA playground. Please help me out with this.
`include "uvm_macros.svh"
class grandchild extends uvm_component;
`uvm_component_utils(grandchild)
super.new(name,parent);
`uvm_info("new", "constructor_gc",0)
`uvm_info("build", "phase_gc",0)
`uvm_info("connect", "phase_gc",0)
`uvm_info("run", "phase_gc",0)
function void report_phase(uvm_phase phase);
`uvm_info("report", "phase_gc",0)
virtual function void display();
`uvm_info("DISP","I'm grandchild",0);
class newgrandchild extends grandchild;
`uvm_component_utils(newgrandchild)
`uvm_info("new", "constructor_ngc",0)
`uvm_info("build", "phase_ngc",0)
`uvm_info("connect", "phase_ngc",0)
`uvm_info("run", "phase_ngc",0)
`uvm_info("report", "phase_ngc",0)
`uvm_info("DISP","I'm the new grandchild",0);
class child extends uvm_component;
`uvm_component_utils(child)
grandchild gc1,gc2;
`uvm_info("new", "constructor_c",0)
`uvm_info("build", "phase_c",0)
gc1 = grandchild::type_id::create("gc1",this);
`uvm_info("build", "created gc1",0)
gc2 = new("gc2",this);
`uvm_info("build", "created gc2",0)
`uvm_info("connect", "phase_c",0)
`uvm_info("run", "phase_c",0)
`uvm_info("report", "phase_c",0)
class env extends uvm_env;
`uvm_component_utils(env)
child c1,c2;
`uvm_info("new", "constructor_e",0)
`uvm_info("build", "phase_e",0);
set_type_override_by_type(grandchild::get_type(),newgrandchild::get_type()); // --> All instances getting overridden. Working fine.
//set_inst_override_by_type("*.e.c1.gc1",grandchild::get_type(),newgrandchild::get_type()); // --> No instance getting overridden. Not working.
c1 = child::type_id::create("c1",this);
c2 = new("c2",this);
`uvm_info("connect", "phase_e",0)
`uvm_info("run", "phase_e",0)
`uvm_info("report", "phase_e",0)
endclass : env
class test extends uvm_test;
`uvm_component_utils(test);
`uvm_info("new", "constructor_t",0)
env e;
`uvm_info("build", "phase_t",0)
e = new("e",this);
`uvm_info("report", "phase_t",0)
uvm_top.print();
e.c1.gc1.display();
endfunction // report_phase
module top;
env e2,e3;
e2 = env::type_id::create("e2",null);
e3 = new("e3",e2);
run_test("test");
