OSVVM library support for questa sim
In Questasim 10.1d , I am unable to see osvvm library in modelsim.ini.
As a result we are getting following errors:
“Error: opcode_fifo/fifo_generator_v12_0/hdl/fifo_generator_v12_0_vh_rfs.vhd(46)): in protected region.”
Also we are using “VHDL93 = 2008 ” in modelsim.ini
Please suggest how to remove this error.
Thanks and regards,
Richa.
OSVVM has only been tested on Questasim versions 10.3 and later. Please update your Questasim to one of these later releases. There is no OSVVM support for earlier versions of Questasim.
In reply to cgales:
As per now we have to stick with the version 10.1d. Is there any way to include osvvm library in this version. Please guide us.
Richa.
In reply to moninarayan:
You will have to go to the OSVVM.org web site. Download the source code and follow the instructions for compiling.
