Region: /mac_pkg
** Warning: (vsim-3764) /export/home/b31_priya/Project/ETHERNET10GMAC/testbench/mac_pkg.sv(19): Stand-alone call to function ‘get’ treated as implicit void cast.
Region: /mac_pkg
** Warning: (vsim-3764) /export/home/b31_priya/Project/ETHERNET10GMAC/testbench/mac_pkg.sv(31): Stand-alone call to function ‘get’ treated as implicit void cast.
Region: /mac_pkg
** Error: (vsim-3567) reset_sequence.sv(18): No field named ‘LOW’.
Region: /mac_pkg::reset_sequence
** Error: (vsim-3567) reset_sequence.sv(19): No field named ‘HIGH’.
** Fatal: (vsim-8274) reset_driver.sv(29): Virtual interface elem. ‘reset_156m25_n’ not found in ‘drv_cb’.
Time: 0 ps Iteration: 0 Region: /mac_pkg::reset_driver File: reset_driver.sv
FATAL ERROR while loading design
Error loading design
THis is my code
`ifndef RESET_ITEM__SV
`define RESET_ITEM__SV
`include "uvm_macros.svh"
class reset_item extends uvm_sequence_item;
typedef enum bit { LOW=0, HIGH=1 } rst_mode;
rand rst_mode reset_n;
// rand bit reset_n;
rand int unsigned cycles;
