in My project environment i am using VIP and iam writing a user defined sequence extended from vip_seq i.e vip_sequence.
in My body task of sequence iam doing get_config(m_sequencer) which results in FATAL error. In this case i have 3 instances of spi agents. like spi_agent #(3) spi_agent_t; and all other interfaces and config as 3.
[b]"UVM_FATAL ::config id has an vip_config_base, but it is not of type spi_vip_config
I am not getting any UVM error when i use only one agent i.e spi_agent #(1) spi_agent
Sample sequence code:
class user_sequence extends from vip_sequence;
config_t cfg; // config_t is the object type defined in vip_sequence.
task body()
cfg = config_t::get_config(m_sequencer); // This results in Error
My question is does m_sequencer gives an error when we have multiple sequencer derived from uvm_sequencer?
How can i resolve this here as iam using VIP, iam not able to declare p_sequencer and use it in my sequence to overcome this limit?
Is there any other way to
