I have a monitor which keep sampling signals when chip_select(active low) is ‘0’, as below:
super.run_phase(phase);
@(posedge vif.sclk);
if ( vif.reset == 1) begin
seq_item_collected.data_in = vif.data_in;
seq_item_collected.cs_in = vif.cs_in;
@(posedge vif.monitor_cb);
if (vif.cs_in == 0) begin //chip_select
seq_item_collected.data_out= (vif.data_out);
trans_collected_port.write(seq_item_collected);
end // reset =1
end //forever
endtask : run_phase
I face some issue here. Since i am stopping sampling as soon as i see cs_in (chip_select) to be low, I have a mismatch on the last data sent.
Since data_out from DUT is avaiable in the next clock after the data_in (is in sync with cs_in), the last data_in is missed.
I wanted to sample just once soon after i see cs_in going high.
I tried to do insert below code:
@(posedge vif.cs_in)
But its not helping. Above code made my test run for very long. I had to break the simulation.
Any better way to do so?
Your monitor implementation has to meet the requirements of your bus protocol. In most cases this protocol makes delays with clock cycles and nothing else.
BTW the cs_in is a control signal and should not be a member of your seq_item class.
@chr_sue, yes i do agtee with your both the points.
Since i am sampling my data_out as per cs_in, i am missing the last transaction. I think, i need to look into it again.
Protocol requires cs_in to be low(active low) for say 400 bytes of pkt. It needs to be aligned with data_in and should go low after last bit of packet. I was confused whether to include cs_in in sequence or driver. Since the packet is generated in sequence, it was easy to generate cs_in in align with packet. Is there a way, i generate packet in sequence and send an event or so to driver to drive cs_in as per packet boundaries? What is the ideal practice to follow in such cases?
You are driving cs_in in your driver. It is useless to have this in the seq_item. Because it has to follow the timimng of your protocol, but the seq_item does not know anything about the timimg…
What do you exactly mean, when saying you llost ther last transaction? Do you not see this transaction in thhe monitor? And why do you not see this transction? Is the simulation stopping meanwhile?
@chr_sue: In our case, cs_in is more like data_valid. It has to be low(active low) just for the frame length. Since, frame boundary info is easily available in sequence, I had implemented it in sequence. But was facing an issue to insert a delay between the frames.
I moved cs_in generation to driver now. Things look good and now have better control.
You are wrong the frame boundary is not known in sequence. The sequencce and seq_item do not know anything about the timing. It knows only the order. Modelling the cs_in in the seq_item creates your problem. Move it out and it will work. You can easily model gaps between the frames with random length.
