I tried to write function bus2reg for UART For write data to register i should receive 3 transactions
1 transaction - write(0x1)/read(0x1).
2 transaction - address.
3 transaction - data.
my function bus2reg
function void bus2reg(uvm_sequence_item bus_item, ref uvm_reg_bus_op rw);
uart_item uart_item_reg;
if(!$cast(uart_item_reg, bus_item))
`uvm_fatal(get_name(), "$cast is failed")
case ({first_step,second_step})
2'b11: begin
rw.data = uart_item_reg.data;
rw.addr = tx_addr;
second_step = 0;
first_step = 0;
2'b10: begin
tx_addr = uart_item_reg.data;
second_step = 1;
default: begin
if(uart_item_reg.data==1) begin // read transaction
first_step = 1;
endcase
IN this case when i do two actions write to registers
ral_model.r1.write (status, 'hFF);
ral_model.r2.write (status, 'hFF);
When i use function get_mirrored_value() i see next →
UVM_INFO uart_test.sv(118) @ 3828: uvm_test_top [uvm_test_top] ral_model.r2.get_mirrored_value(): FF
UVM_INFO uart_test.sv(119) @ 3828: uvm_test_top [uvm_test_top] ral_model.r1.get_mirrored_value(): 0
I think it’s because inside function bus2reg i rewrite value register r1 after first transaction (for register r2)
i did next logic in my project for resolve this problem but i think it is not correct
// function bus2reg
**rw.status = UVM_NOT_OK;**
2'b11: begin
rw.status = UVM_IS_OK;
rw.addr = tx_addr;
second_step = 0;
first_step = 0;
2'b10: begin
second_step = 1;
default: begin
first_step = 1;
endcase
**if(rw.status != UVM_IS_OK) begin
rw.addr = 'hFF;
rw.data = 'h00;
end**
After this logic i see next
UVM_INFO uart_test.sv(119) @ 3828: uvm_test_top [uvm_test_top] ral_model.r1.get_mirrored_value(): FF
Could you help me - is it correct for function bus2reg?
rw.addr = 'hFF;
rw.data = 'h00;
end**
Project in EDA UART_UVM_2.1_frondoor_seq - EDA Playground
